Civil 3D Forum
Point Description gets truncated
6 REPLIES 6
432 Views, 6 Replies
In LDDT 2009, I was able to describe points like this: STK #32
But in Civil 3D 2013, whenever I use the # symbol, the description gets truncated.  So, using the point description above, it will show up in Civil 3D 2013 as STK rather than STK #32.
Is this a setting or something that I can switch on so that the I can use symbols such as # and - in my point description?
6 REPLIES 6
tcorey
Are you using Description Keys? If so, check the Format column of the description key that is not working. Try setting that to $* and see if you get the # sign.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
in reply to: tcorey
Yes, I checked the description key format and it is set to $*.
Is it something to do with the Point Label Style for "description" that I have to change?
tcorey
It's possible that you have Raw description being called rather than Full Description. Check the Contents of the Description component of your label style.
Tim Corey
Redding, CA
in reply to: tcorey
It was already set to Full Description.
I got it to work.  I changed it to Raw Description, reimported the points and it showed up they way I wanted to.
Thanks for your help.
Rail Community
