Active Member
isabelle_dizface
Message 1 of 9 (732 Views)
Point Coordinates
732 Views, 8 Replies
12-13-2012 09:01 AM
Hi!
I am completely new to Autocad Civil (and quite new to Autocad generally) and am having some issues with the creation of points.
The file I am working from is a plan drawn in 2D Autocad. I have used it as an external reference to draw parcels in Civil. Using the Points Creation tool / Miscellaneous / Automatic option, I am creating points at each corner of the said parcel. The coordinates for the points created are completely off, to the extent of being negative when my SCU DEFINITELY means that they should be positive. I am wondering if these pointsthat are generated automatically are linked to a different origin (0;0;0) or based on a separate grid? If so, how do I get them to correspond to the same coordinate system as the rest of my geometry?
I am going crazy trying to find the answer, and hopefully my question above is clear enough for someone to help!
Hey!
It turns out that i needed to move my chosen origin point to the ABSOLUTE origin instead of moving the SCU only. I did it with MOVE then # in front of the coordinates.
Thanks for the help! :smileyhappy:
troma
Message 2 of 9 (726 Views)
Re: Point Coordinates
12-13-2012 09:10 AM in reply to: isabelle_dizface
What User Coordinate System are you in?
Type UCS at the commandline.  You need to be in World.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Member
isabelle_dizface
Message 3 of 9 (677 Views)
12-14-2012 12:20 AM in reply to: troma
Yep, I've been in World all of the time...
Valued Mentor
KirkNoonan
Message 4 of 9 (663 Views)
Verify that the zone in your drawing is set correctly - W...
12-14-2012 05:58 AM in reply to: isabelle_dizface
Verify that the zone in your drawing is set correctly - Workspace - Settings tab - right click on drawing name and select edit drawing settings.
Also verify that the base drawiing you are using was inserted at 0,0 (or the appropriate location) and that it was inserted in feet instead of inches and not rotated
Valued Mentor
Valued Mentor
sjg
Message 5 of 9 (651 Views)
12-14-2012 11:26 AM in reply to: isabelle_dizface
Where did you receive the drawing? Are you sure it was even drawn in a system? With your cursor, hover over the site and in the lower left of the screen what are the numbers you're seeing.
Steve Goessling
Land Consultants
Civil3D 2013
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
AllenJessup
Message 6 of 9 (643 Views)
12-14-2012 12:30 PM in reply to: isabelle_dizface
Also check the UCS in the 2D AutoCAD drawing and make sure that either that drawing is in Feet (or Meters) or that it's been correctly scaled when Xrefd. If it is in the correct units. Make sure it wasn't inadvertently scaled when Xrefed.
Active Member
isabelle_dizface
Message 7 of 9 (592 Views)
01-07-2013 09:07 AM in reply to: AllenJessup
Hey!
Active Contributor
dsigman
Message 8 of 9 (577 Views)
01-07-2013 12:02 PM in reply to: isabelle_dizface
I'm curious what SCU stands for. I've been around CAD for years as a surveyor and I've never heard of it.
AllenJessup
Message 9 of 9 (571 Views)
01-07-2013 12:09 PM in reply to: dsigman
I think it's the French language version of UCS.
