I need some help. Our company recently started using Civil 3D for surveying projects. When I am importing .csv files into Civil 3D, the points will preview with the correct Northing & Easting, yet when inserted into the drawing using the "import survey data" function from the survey prospector tab, they have a different Northing & easting in the model. It is a consistent amount different from the raw data, so it is not a scaling issue. The points will list with the correct northing and easting, yet ID'ing the point in CAD gives me a different result. Has anybody else had this issue before? Units set to US Survey feet and Base is at 0,0,0.
Please help.
Bob Boyer, PLS
Solved by rl_jackson. Go to Solution.
Are your drawing setting and survey database settings the same.
Rick Jackson
Survey CAD Technician VI
I fixed the problem. The survey database settings was to US Survey feet but the AutoCAD settings were to International feet. Once I set both the same, it worked fine.
Thanks for the help.
