I might be missing somehting completely, but I am reading with Civil 3D 2013 you should be able to clip a Point Cloud, but I am not seeing the clipping panel under the point cloud tab. Is there anything special that you need to do to get to this?
Solved by otter. Go to Solution.
I am here on the forum waiting for a point cloud to finish loading. Is there anyway to only load PART of a point cloud; similar to Map import with geographical queary?
I only need two small fractions of the lidar topo data, not the entire county.
