FYI,
Just highlight the label in the edit window, the formatting will show on the
left. Change the values and then hit the arrow. I think it's a little
faster then having to delete and create a new one.
Matt Sparks, P.E.
CAD Masters, Inc.
http://www.cadmasters.com
"wfb" wrote in message
news:5009022@discussion.autodesk.com...
When changing the precision in the composer, you should delete the existing
one and make a new one. Use the large ->(Arrow) and send it in.
As far as changing the descriptions, you did everything correct up to a
point, RT click the title in the column change description and it will
change the rest.
Bill
wrote in message news:5009001@discussion.autodesk.com...
Also, I changed the elevation precision setting in at least three different
locations to 2, but points created still have elevation labels to the third
decimal point. I can see how these styles can be a great thing when properly
set up, but the number of settings and different locations where the same
setting can be changed is completely overwhelming to me. Does anyone else
feel this way?
