AutoCAD Civil 3D General Discussion
*Expert Elite*
antoniovinci
Message 11 of 18 (653 Views)
Re: PNT files
03-16-2012 11:43 AM in reply to: Jeff_M
Jeff_M wrote:
does he shoot contours, or does he shoot points with elevation?
He shoots points with elevation, then he comes back home, and the very first thing he makes is.. contours from those points.
Contours are the base for every serious topographic plan: how did you project before computer era?
Answer: in 2D, on a contour basis, trust me.
If somebody lets me choose between a bunch of 3Dfaces (TIN) or a shape with elevated contours, I go with the second one, without no doubt, dear Jeff.
Distinguished Mentor
andrewpuller3811
Message 12 of 18 (637 Views)
Re: PNT files
03-18-2012 03:11 AM in reply to: antoniovinci
The first thing that gets done with points are that they are added to a surface in civil 3d from which trianlges are created, from which contours are interpreted. Check out what gets changed when contours are smoothed.
When I carry out a topo survey I measure points (and breaklines) that will create a surface model that will give the best representation in the computer of the actual ground, based on triangles.
Before computers, surfaces were drawn with contours, which were calculated from the points that surveyors measured. The surveyed points were plotted onto paper then measured between to calulate the elevations that were to be drawn as contours. The contour lines would then be drawn smoothly between all the calculated elevations of the same height to give your contour plan. The same process that occurs with a tin surface in computers.
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
*Expert Elite*
BrianHailey
Message 13 of 18 (629 Views)
Re: PNT files
03-18-2012 10:55 AM in reply to: antoniovinci
Contours are a lie. I would MUCH rather have the triangles of the surface then an approximation of the surface aka contours. If you build a surface from contours, what is happening between the contours? You have absolutely no idea. If you get the triangles, you have the maximum amount of information from that surface. Do you build from contours? No. You build from points. The contours are simply a graphical representation of those points that make it simple for us as humans to see what is going on.
I hate to say it but I disagree with you, Antonio (I'm assuming that's your first name). But hey, that's the great part about this discussion group, people disagreeing with you is a great way to learn.
Brian Hailey
CAD-1.com
My Blog
*Expert Elite*
wfberry
Message 14 of 18 (605 Views)
Re: PNT files
03-19-2012 09:27 AM in reply to: BrianHailey
Brian:
The biggest problem that I have here is agreeing with Jeff, ALL THE TIME.
Oh well, maybe, someday!
:mansad:
Bill
aportillojr
Message 15 of 18 (598 Views)
Re: PNT files
03-19-2012 03:11 PM in reply to: Jeff_M
I am going to consider this issue resolved for me.  In future I will ask for LandXLM file.  I was actually looking for points.  When I received the .txt file with point information, I imported .txt file and got what I was looking for.  I appreciate all the good answers.  When I called the surveyor, he didn't know anything about a .pnt file. I use him regularly therefore I will just get the .txt file and insert it.
Thanks again,
Mando
Valued Contributor
jmatte2004
Message 16 of 18 (583 Views)
Re: PNT files
03-20-2012 09:56 AM in reply to: aportillojr
tell your surveyor to throw away that toy for software he has and get some real software. i always have problem with surveyor that have carlson. i bata tested it when it first came out and even meet with the developer to get him to fix the problems. seems like they still have some of the same problems today.
Distinguished Contributor
Hammer.john.j
Message 17 of 18 (334 Views)
Re: PNT files
08-23-2013 06:37 AM in reply to: antoniovinci
contours CAN be basis for work if the contours are from an Aerial Survey using photogrammitry and mathematical cmoputations to out put contours...
Different types of survey are source data are applicable to different project types and accuracies with most detailed contouring requiring field survey which uses the compilation of points to create a grid surface or triangulated irregular network (surface).  Surfaces can also be made from aerial survey points acquired from LiDAR for instance.
http://en.wikipedia.org/wiki/Triangulated_irregular_network
John Hammer, LA
Dell Precision T3500 - Xenon W3550 @ 3.07 (4 core)
Ram @ 12Gb
64bit Win7 Pro
Samsung SSD
NVIDIA Quadro 2000 - Dual Monitors
Cat 6 network with GlobalScape Avail Agent - WAFS
Infrastructure Design Suite Premium and Civil 3D 2012 & 2014
Hammer.john.j
Message 18 of 18 (332 Views)
Re: PNT files
08-23-2013 06:43 AM in reply to: jmatte2004
Carlson is actually a very good program for Survey, it works very well with data collectors (Trimble I think?).  Civil 3D is a good upgrade but not being a surveyor, I can't say if Civil 3D handles field to finish as well as Carlson or how well it works with Data Collectors.  Carlson actually works quite well with Civil 3D and to the O.P.... consider asking for:
XML of surface
text file of points
2D Cad linework
YOU DON'T need their triangles, their cad blocks (survey shots) but you PROBABLY want their contours to get their representation of the contours to make sure Civil 3D's interpretation of the XML file matches....
John Hammer, LA
Ram @ 12Gb
64bit Win7 Pro
Samsung SSD
Announcements
Need installation help?
