I'm trying to plot a corridor via an XREF but the links etc do not plot although if I plot the same drawing via it's own layout tab there is no problem and the corridor plots as expected.
I need to xref into a sheet set and to get the plans out of the door but can't see why this is happening so any suggestions gratefully received.
In the interim I exploded the corridor and wblocked to a new file which I then xrefed and it behaved as expected i.e. showing the links etc.
This is either a major bug or I am doing something phenomenally stupid (hopefully the latter)
Neil
neilyj (No connection with Autodesk other than using the products in the real world)
Did you try checking the layer for the links and make sure it's turned on? I seem to recall many versions ago (could be remembering wrong, though) that the drawing that the corridor is being XREF'd into must also have the same code set style and layers. But I might be getting confused with another issue regarding corridors.
