Hi all,
When i am creating section sheets from multiple section views ,section sheet view port scale changes.I did set it correctly in my template.
For example it changs from 1:150 to 1:150_1
Then in section sheets scetions views are not displaying correctly.
When i change view port scale manually it shows correctly.But it should do to all sheets.
What should I do?
In model spacr multiple section views are showing correctly.
Pls help me,
Solved by andrewpuller3811. Go to Solution.
Oh I forget it.I am using
AutoCAD Civil 3D 2011
I don't have 2011 installed anymore, and I don't recall that ever happening to us. It might be helpful if you posted the dwg for someone to take a look, or to open a case with support, if you're on subscription. I've been trying to reproduce this in 2012 without success. Perhaps if you posted your template, I could try it in 2012 using your settings.
Check your template you have for the section views.
It sounds like it might be the scales are defined differently for 1:150.
I would compare the definition of the 1:150 scale in your drawing you are working in and then compare that to the definition of the 1:150 scale in the template you have for the section views. Also check the scale attached to the viewports in the template you have for the section views.
Hi ,
Thanks for all answers,Then check all places where should scale.It all right.I attach all my dwgs.
You can see in my layouts sections are not displaying correctly.
Pls check it and give me some help.
Sorry
I should say
Then check all places where should set scale.It is all right.
The problem is with your template.
The units are set to millimeters instead of meters.
Even though the definition for the 1:150 scale is technically the same in each drawing, have the template units set to millimeters is causing the scales to to be converted from 1 paper millimeter = 150 drawing millimeters in the template to 1 paper millimeter = 150 meters.
You need to open your template, in the Toolspace -> Settings tab ->Right Click on the drawing name -> Edit Drawing Settings -> Units and Zone tab -> Drawing units: - set to Meters
I would also ensure the check box "Set Autocad variables to match" is checked.
Click ok.
When the above is done, all locked viewport scales get changed from their existing scale to a new scale 1000 times the original. for example, the 1:150 scale of 1 paper millimeter = 150 drawing millimeters gets changed to 1:150_1 with setting of 1 paper millimeter = 150 meters. So you need to change the viewport scales back to their original scales.
Save the template.
Go back to your drawing and create your section sheets again.
Hello all,
It is working.Big thanks to andrewpuller.
But I can't understand it.
Pls give me some links to get full knowlege about "Headling scale in AutoCAD and Civil 3D".
