Active Contributor
dankoss
Message 1 of 14 (488 Views)
Plotting a Symbol Over a Line
488 Views, 13 Replies
11-01-2012 10:28 AM
Hi Everybody,
I'm having trouble plotting a symbol over a line. For example, I'm doing a corner record and need to put our symbol for a set pipe on the corner of the property line. Our symbol for a pipe is just an open circle. I want to put the circle on the corner and do not want the the property line to be shown inside that circle. Essentially I want to make it look like I trimmed the line inside the circle but I want to leave the line intact so there is no gap in the boundary. What is the way to do something like this?
I create a wipeout and put it under the symbol but above the lines. You can't create a circular wipeout. So create a polygon with numerous sides that just fits around your symbol, I use 20 sides for mine, then create a wipeout by polyline and select the polygon. Use draw order to move it below the symbol. You'll also want to make the frame of the wipeout a no-plot color. You could turn the frames on and off but I find that to be troublesome because it turns the frames off for all the raster images.
Since you'll want this to happen all the time. Make the wipeout part of your block. I also have a block called WipeoutCircle that I can insert as needed.
Allen
AllenJessup
Message 2 of 14 (485 Views)
Re: Plotting a Symbol Over a Line
11-01-2012 10:40 AM in reply to: dankoss
Allen
Active Contributor
dankoss
Message 3 of 14 (479 Views)
11-01-2012 11:16 AM in reply to: AllenJessup
Thanks for the reply, that's exactly what I needed.
Valued Contributor
PatrickManson
Message 4 of 14 (459 Views)
11-01-2012 12:38 PM in reply to: dankoss
Another option is that if you are plotting using viewports, you give your block an elevation higher than the linework, and then right click on your viewport - shade plot - hidden, and when you plot the line inside your block will not display.....
fautodesk
Message 5 of 14 (450 Views)
11-01-2012 01:57 PM in reply to: dankoss
You can also change your label style for the line to include the "_wipeout_circle" block. I believe this block is included OTB. This will automatically add the circle with the wipeout to the beginning and/or end of your line.
BrianHailey
Message 6 of 14 (441 Views)
11-01-2012 02:23 PM in reply to: fautodesk
Hey! Look at that! I never even noticed that block in there! That will come in handy for sure!
Brian Hailey
CAD-1.com
My Blog
AllenJessup
Message 7 of 14 (404 Views)
11-05-2012 05:39 AM in reply to: fautodesk
I hadn't notice that either. I've been using my own for years. Even the same name, minus the undrebar (_).
Allen
troma
Message 8 of 14 (382 Views)
11-06-2012 07:29 AM in reply to: fautodesk
Where is that block?
Thanks.
Credit where credit is due! Give kudos or accept as solution whenever you can.
AllenJessup
Message 9 of 14 (376 Views)
11-06-2012 07:38 AM in reply to: troma
It looks like it's included in the OOTB templates. If you started your template from one of those, you should be able to Insert a block called _Wipeout Circle. If not, you can extract it from a template and include it in yours.
If you need to mask an area that is not circular but elliptical. You can change the scaling of the block to produce an ellipse. You can also produce wipeouts of any shape yourself and make them blocks.
Allen
fautodesk
Message 10 of 14 (374 Views)
11-06-2012 07:42 AM in reply to: troma
Your general line label styles allow you to add blocks as part of the style. You will need to add a block to the style, change the name to suit your taste, then select block name under where it says 'block'. It will open a pulldown menu where you can select from blocks in your drawing. I have attached pics to help.
