remmnate wrote:
> If someone has some time to take a look at this drawing and see if its just me or if this drawing is corrupted. Every time I go to plot and try a plot preview I get a fatal error and crash bang boom.....there I am at my desktop again. I only have 3d installed on one machine so I have no way to check it out. If someone wants to take a look and see if it will do the same thing in a different environment be my guest.
Lisa Pohlmeyer >> wrote:
> kbarn wrote:
>> have been getting the error message "A Startup Problem - The A
program name changed from a.exe to acad.exe Some commands and add-on
customizations may not load correctly. Continue anyway?" when I try to
open LDT 2007 or Civil 3D 2007. Clicking Yes freezes everything with the
message "Error loading AcStandards services".
>> My solution was to uninstall all my modules and reinstall but
unfortunately I was able to uninstall everything (Raster, Survey, Civil
3D Companion and
> LDT 2007) except Civil 3D 2007. I get an error message "Fatal error
during installation" so I can't get rid of it. My dealer hasn't seen
this one yet. Has anybody?
>> Help!!
> I inserted your drawing into a new 2007 dwg, created from a new 2007
> template (not one migrated from
> a previous version.) I then ran an audit:
> Command: audit
> Fix any errors detected? [Yes/No] :
> Auditing Header
> Auditing Tables
> Auditing Entities Pass 1
> AeccDbTreeNode(8B) was not repaired.
> Pass
> 1 100 objects audited
> AeccDbTreeNode(8C1) was not repaired.
> Pass 1 5400 objects audited
> Auditing Entities Pass 2
> Pass 2 5400 objects audited
> Auditing Blocks
> 72 Blocks audited
> Total errors found 0 fixed 0
> Erased 0 objects
> Then I exploded the inserted dwg...
> Command: explode
> Select objects: 1 found
> Select objects:
> Associatve hatch entity on locked or frozen layer. No update performed.
> med.
> Nothing wierd there...
> Another Audit yielded not errors...
Wrong thread.... but it wouldn't let me recall... sorry.... should have
been a reply to PLOT PREVIEW CAUSING CRASH
Lisa
> Ran the -purge command:
> Command: -purge
> Enter type of unused objects to purge
[Blocks/Dimstyles/LAyers/LTypes/MAterials/Plotstyles/SHapes/textSTyles/Mlinestyl
> es/Tablestyles/Visualstyles/Regapps/All]: r
> Enter name(s) to purge <*>:
> Verify each name to be purged? [Yes/No] : n
> Deleting registered application "ACAD_DSTYLE_DIM_EXT1_LINETYPE".
> Deleting
> registered application "ACAD_DSTYLE_DIM_EXT2_LINETYPE".
> Deleting registered application "ACAD_DSTYLE_DIM_LINETYPE".
> Deleting registered application "ACAD_PSEXT".
> Deleting registered application "ADE_PROJECTION".
> Deleting registered application "AECBASE".
> Deleting registered application "svPLINE".
> Deleting registered application "SVUI_FIGURE_XDATA".
> 8 registered applications deleted.
> Nothing strange here either...
> However, all your point groups needed to be updated, which wouldn't
execute=
But I did find something, take a look at the attached jpg, there's a
problem with one of your parcel lines and the endpoint elevations...
HTH
Lisa
