AutoCAD Civil 3D General Discussion
*Dave D
Message 1 of 15 (126 Views)
PLINEGEN on alignments, profiles
126 Views, 14 Replies
11-09-2004 02:40 PM
I've noticed that I can't get a smooth linetype working on alignments and profiles, especially on profile surfaces because of the TIN sampling interval. Our standard is to show existing profile grade lines as HIDDEN. Is there an option to apply PLINEGEN to these entities? I do have PLINEGEN =1 before importing the profile. If not, I'll just have to use the "Continuous" linetype. Thanks, Dave D.
*James Wedding
Message 2 of 15 (126 Views)
Re: PLINEGEN on alignments, profiles
11-09-2004 02:57 PM in reply to: *Dave D
It's been logged as a bug. One of my BIGGEST issues. -- James Wedding, P.E. IT Manager Jones & Boyd, Inc. Dallas, TX XP/2 on P4-3.4/1G LDT2005+C3D http://au.autodesk.com Sign up now for AU2004!
*Don Reichle
Message 3 of 15 (126 Views)
11-09-2004 03:06 PM in reply to: *Dave D
The Ways of the Work-Around... So we then need to Export the Profiles through LandXML to LDT, and then choose the Company Standard Linetype? I would hope they issue a patch instead of waiting for the Spring 2005 release! But I hope we don't see the infamous c4a patch identifier. -- Don Reichle Hacker Engineering, Inc. "King of Work-Arounds" LDT & CD 2004 C3D 2004 SP1 On HP Pavilion a367c 2.80 Ghz/512MB RAM XP PRO - SP2 "James Wedding" wrote in message news:41914b72$1_1@newsprd01... > It's been logged as a bug. One of my BIGGEST issues. > > -- > James Wedding, P.E. > IT Manager > Jones & Boyd, Inc. > Dallas, TX > XP/2 on P4-3.4/1G > LDT2005+C3D > http://au.autodesk.com > Sign up now for AU2004! >
*Dave Simeone
Message 4 of 15 (126 Views)
11-10-2004 06:23 AM in reply to: *Dave D
Are there cases where you're drafting anything other than EG surface profile lines as a dashed linetype? Would you ever draft the FG profile line as dashed? Maybe the EOP or other offset lines may be dashed lines? I'm guessing that the answer is - "we need the option to make any profile line dashed/solid, etc" - but I need to ask the question. Thanks DAS "James Wedding" wrote in message news:41914b72$1_1@newsprd01... > It's been logged as a bug. One of my BIGGEST issues. > > -- > James Wedding, P.E. > IT Manager > Jones & Boyd, Inc. > Dallas, TX > XP/2 on P4-3.4/1G > LDT2005+C3D > http://au.autodesk.com > Sign up now for AU2004! > >
*Don Reichle
Message 5 of 15 (126 Views)
11-10-2004 06:56 AM in reply to: *Dave D
Hey Dave; As you expected the answer you guessed at was the correct one. In return, I will ask why would it be otherwise? We are at the mercy of the agencies whose jurisdictions we do Useful Work in. The cities of Eugene and Springfield, Oregon are only separated by I-5, and their standards are distinct to each. And they are both distinct from Lane County that surrounds them. Whatever their standards are, that's what we must follow. So we need all the flexibility we can get! But, hey, thanks for asking. We very much appreciate being part of the loop. -- Don Reichle Hacker Engineering, Inc. "King of Work-Arounds" LDT & CD 2004 C3D 2004 SP1 On HP Pavilion a367c 2.80 Ghz/512MB RAM XP PRO - SP2 "Dave Simeone" wrote in message news:4192245c_2@newsprd01... > > Are there cases where you're drafting anything other than EG surface > profile > lines as a dashed linetype? Would you ever draft the FG profile line as > dashed? Maybe the EOP or other offset lines may be dashed lines? > > I'm guessing that the answer is - "we need the option to make any profile > line dashed/solid, etc" - but I need to ask the question. > > Thanks > DAS > > "James Wedding" wrote in message > news:41914b72$1_1@newsprd01... >> It's been logged as a bug. One of my BIGGEST issues. >> >> -- >> James Wedding, P.E. >> IT Manager >> Jones & Boyd, Inc. >> Dallas, TX >> XP/2 on P4-3.4/1G >> LDT2005+C3D >> http://au.autodesk.com >> Sign up now for AU2004! >> >> > >
*Ron Mills
Message 6 of 15 (126 Views)
11-10-2004 07:03 AM in reply to: *Dave D
"Dave Simeone" wrote in message news:4192245c_2@newsprd01... > > Are there cases where you're drafting anything other than EG surface profile > lines as a dashed linetype? Would you ever draft the FG profile line as > dashed? Maybe the EOP or other offset lines may be dashed lines? Dave, I do landfill profiles. Within these profile views, there are generally between 9-10 different profiles (Previous EG, EG, FG, separate cell profiles). It would be nice to have several of these as dashed, particularly the cell profiles (with a light lineweight) and the Previous EG (with a heavier lineweight)
*Dave D
Message 7 of 15 (126 Views)
11-10-2004 07:48 AM in reply to: *Dave D
I'm trying not to export anything back into LDT unless I need to do Pipes / Hydrology. keepin' on movin' forward. "Don Reichle" wrote in message news:41914d6f$1_2@newsprd01... > The Ways of the Work-Around... > > So we then need to Export the Profiles through LandXML to LDT, and then > choose the Company Standard Linetype? > > I would hope they issue a patch instead of waiting for the Spring 2005 > release! > > But I hope we don't see the infamous c4a patch identifier. > > -- > Don Reichle > Hacker Engineering, Inc. > "King of Work-Arounds" > LDT & CD 2004 > C3D 2004 SP1 > On HP Pavilion a367c > 2.80 Ghz/512MB RAM > XP PRO - SP2 > > > "James Wedding" wrote in message > news:41914b72$1_1@newsprd01... >> It's been logged as a bug. One of my BIGGEST issues. >> >> -- >> James Wedding, P.E. >> IT Manager >> Jones & Boyd, Inc. >> Dallas, TX >> XP/2 on P4-3.4/1G >> LDT2005+C3D >> http://au.autodesk.com >> Sign up now for AU2004! >> > >
*Dave D
Message 8 of 15 (126 Views)
11-10-2004 07:54 AM in reply to: *Dave D
Yes Dave. There may be times where we need to show right and left offsets from centerline. In that case, I'd use something like DASHDOT or DIVIDE. I can do this now, but the linetype does not generate smoothly through vertices. Well let's say I can do this now in most cases. One profile grade line that I have has many vertices taken from a what I'll call a tightly constructed TIN. So there are many elevations taken at short horizontal distances along the grade line, creating many vertices and a CONTINUOUS looking linetype. Dave D. "Dave Simeone" wrote in message news:4192245c_2@newsprd01... > > Are there cases where you're drafting anything other than EG surface > profile > lines as a dashed linetype? Would you ever draft the FG profile line as > dashed? Maybe the EOP or other offset lines may be dashed lines? > > I'm guessing that the answer is - "we need the option to make any profile > line dashed/solid, etc" - but I need to ask the question. > > Thanks > DAS > > "James Wedding" wrote in message > news:41914b72$1_1@newsprd01... >> It's been logged as a bug. One of my BIGGEST issues. >> >> -- >> James Wedding, P.E. >> IT Manager >> Jones & Boyd, Inc. >> Dallas, TX >> XP/2 on P4-3.4/1G >> LDT2005+C3D >> http://au.autodesk.com >> Sign up now for AU2004! >> >> > >
*Angel Espinoza
Message 9 of 15 (126 Views)
11-10-2004 08:44 AM in reply to: *Dave D
Hi Dave, Sometimes, I've seen the need for superimposed profiles to be dashed. So the answer is a Yes. Angel Espinoza KETIV Technologies "Dave Simeone" wrote in message news:4192245c_2@newsprd01... > > Are there cases where you're drafting anything other than EG surface profile > lines as a dashed linetype? Would you ever draft the FG profile line as > dashed? Maybe the EOP or other offset lines may be dashed lines? > > I'm guessing that the answer is - "we need the option to make any profile > line dashed/solid, etc" - but I need to ask the question. > > Thanks > DAS > > "James Wedding" wrote in message > news:41914b72$1_1@newsprd01... > > It's been logged as a bug. One of my BIGGEST issues. > > > > -- > > James Wedding, P.E. > > IT Manager > > Jones & Boyd, Inc. > > Dallas, TX > > XP/2 on P4-3.4/1G > > LDT2005+C3D > > http://au.autodesk.com > > Sign up now for AU2004! > > > > > >
*scott mceachron
Message 10 of 15 (126 Views)
11-10-2004 06:10 PM in reply to: *Dave D
Tyler Texas - EG profiles are sampled 16.5 feet left and right, 30 feet left and right, and 45 feet left and right of the centerline - 7 profile lines in each profile view; not real purdy in their current state. sm -- Scott McEachron The D.C. CADD Company "Dave Simeone" wrote in message news:4192245c_2@newsprd01... > > Are there cases where you're drafting anything other than EG surface > profile > lines as a dashed linetype? Would you ever draft the FG profile line as > dashed? Maybe the EOP or other offset lines may be dashed lines? > > I'm guessing that the answer is - "we need the option to make any profile > line dashed/solid, etc" - but I need to ask the question. > > Thanks > DAS > > "James Wedding" wrote in message > news:41914b72$1_1@newsprd01... >> It's been logged as a bug. One of my BIGGEST issues. >> >> -- >> James Wedding, P.E. >> IT Manager >> Jones & Boyd, Inc. >> Dallas, TX >> XP/2 on P4-3.4/1G >> LDT2005+C3D >> http://au.autodesk.com >> Sign up now for AU2004! >> >> > >
Announcements
Need installation help?
