Firstly i received a drawing from architect and that is the fiirst attached file. architectural drawing
Secondly if i insert and explode it the result i got is very confusing, i did not know why it display that way. what might be responsible? a. i attached the result and called it scale drawing.
Thirdly, the last attached file is my drawing, in this drawing i created a point IP and move the point to a new Northing and Easting(100.000,100.000). if you hover over the drawing at the point IP my coordinate will be 100,100 but when you check the same point it will give different coordinate.
Solved by andrewpuller3811. Go to Solution.
Big,
Don't know where you got the drawing, but this dialogue box came up when I tried to open your first attached file:
Dave
Dave Stoll
Las Vegas, Nevada
Obviously there is a mixture of feet and meters mixed here and there in this file(s).
I can tell you if you change "my drawing" to feet in Drawing Settings your point will change to 100,100.
Bill
@Pointdump it normally happen when you try open a drawing that was created with a higher version. just click continue
@ pointdump it normally happen when you try open a drawing that was created with a higher version. just click continue
@wfberry if that is the case how do i convert the feet drawing to meter.if you check mthe second file i try to scale it but the result is oooosppp. everything went on their different direction
I do not know what your background involves. Do you realize that there are .dwt templates that are to be used prior to beginning a drawing? The .dwt is just a simple .dwg file that is configured to be either imperial feet or metric. It is somewhat difficult after the drawing has been used to get all the parameters configured properly.
I would suggest that you begin with a new set of .dwt's and start over. An architectural drawing is another matter but I would suggest that the propert .dwt file be used and insert the arch. file into it.
Bill
Big,
Follow Bill's advice. He's steering you right.
"... a drawing that was created with a higher version."
Couldn't crack it with 2014. Message was too scary to continue. Bill is braver than I.
Dave
Dave Stoll
Las Vegas, Nevada
I have to say that the drawing achitectural drawing.dwg is interesting. The "Units" as set for autocad are centimetres, and the dimensions are all shown in millimetres. To add to that, the civil 3d settings have the drawing in inches.
If I start with a metric template which has the units set to metres (in the toolspace palette -> settings tab, right click on the drawing name and select "Edit Drawing Settings...", then set Drawing Units to "Meters" if it is not already - if you start from a metric template, this should already be the case. Then use the "units" command and set the Length to Decimal, Insertion scale to Meters), and insert the drawing "achitectural drawing.dwg" as a block using the "insert" command. This will show that the source drawings units are in centimetres and also show the scale factor to be used to scale the drawing to bring it to the current drawings units. It should read 0.01 for centimetres to metres, anything else and you target drawing is not in metres.
I would not set the block to explode initially, as it will allow you to position it as one entity rather than trying to manipulate thousands of entities.
With regard to the scale drawing, this is the mess that happens when dimension style for one set of units get applied to a drawing that has another set of units.
To fix this, select all the dimensions in the drawing, (I select a few different ones, then right click and choose "select similar", but I'll leave that to you) right click and choose properties. In the properties palette, set the Dimscale Overall to 0.01 (this reflects the units scaling applied when the block is inserted - i.e centremetres to metres -> 1 cm : 1 m give 1:100 = 0.01). The dimscale overall controls the appearance of the entire dimension entity, so the setting above will scale all the objects in the dimension by 0.01. The measurement shown will be in decimetres (10s of centimetres) due to the source drawing being in centimetres, with dimensions shown in millimetres, which will be fixed next. Now set the Dimscale Linear to 1000 to get the dimensions showing in millimeres again. You could set the value to 1 to get the dimensions shoiwing in metres, but then you need to set the Dim roundoff to 0.001 and the Precision to 0.001.
In regard to your drawing, but as pointed out by bill, it the point was put in using US survey feet, the location of you point would be 100,100, which lead me to figure it is your Point Label Style and Drawing Coordinate Units that are wrong.
To fix your Point Label Style, edit it in the toolspace (Toolspace palette => Settings tab = > expand the Point node = > expand the Label Styles node, select the label style joel, right click and chose Edit...). Now edit the contents of the text by clciking on the elipsis button at the right side of the Contents box. Select the Text for the northing ( <[Northing(Uft|P4|RN|AP|GC|UN|Sn|OF)]> ) in the text editing window, making sure the entire text for the nothing is highlighted blue. On the left, change the Unit from foot to meter and the Precision to 0.001 and click the Arrow next to the property drop down. This will update the text in the text window for the northing to read <[Northing(Um|P3|RN|AP|GC|UN|Sn|OF)]>. Do the same for the easting and then click OK and then OK. you should see the coordinates of your point label update immediatley to 100.000, 100.00.
To fix the Drawing Coordinate Units, go to the Toolspace palette => Settings tab and right click on the drawing name and choose Edit Drawing Settings... On the Ambient Settings tab, you will need to expand the Coordinate item and change the Unit from Foot to Meter. There are other unit settings here that need fixing, being Distance, Dimension, Elevation, Area, Volume, Speed, Station and Acceleration.
Personally, I would delete that drawing and start with a fresh drawing based on a metric template and import your settings.
In regards to the achitectural drawing.dwg drawing, I would be asking the architect whether you should set out the dimensions or the grid lines? If you check, the dimensions on the left side of the drawing are not precisely on the grid lines they are dimensioning. The dimensions between grid lines C and H are the ones in question.
@bigexploit wrote:
But selecting the one entity did not work because the check box for
annotation has been permanent ly place to NO. So it is very difficult to
change it to the current scale of the drawing.
I would not bother with the annotative property as this will make more work than the fix method I posted. If you do go with changing to annotative, you will need to modify all the annotation properties, arrow size, text size, line offsets, line extensions and on and on...
