Hi
I have a question; how i can create a surface if i just have an alignment and some cross section views?
Any help would be appreciated.
Thanks.
Solved by neilyj666. Go to Solution.
neilyj (No connection with Autodesk other than using the products in the real world)
@neilyj666 wrote:
There is a tool xsect2surf that may help - not on PC now so can't give anymore details but try googling.
That really looks interesting but the latest link I could find says it's for C3D 2012 or 2013.
http://autodesk.typepad.com/transportation/2012/10/x-section-to-surface.html
EDIT: I saw one link that referred to this task as "Reverse Engineering the Cross Section". That seems appropriate.
Don Ireland
Engineering Design Technician
actually i dont have the survey data yet. So i dont know what kind of cross section i will use, but usually the sections are drawn in autocad if that is what you mean
Thank you very much neilyj it works perfectly. in the link that doni49 posted. If anyone have the same problem, just click the link. There is an tutorial video and the download link of what i suppose is an autolisp subroutine
