Hi.
How can I change my first selected composition? How can I create them again if I deleted them?
I mean, from "ISO A1" to "ISO A3".
In this part, I can´t modify values:
planes tab in secction views group properties:
Thanks in advance.
Sorry for my English.
Solved by Pointdump. Go to Solution.
J,
From the Help Section:
Selected Layout
Displays the layout within the selected template that was used when the section views were created. The layout cannot be changed after the section views are created. To select a new layout, re-run the Create Multiple Views command and select a different layout.
Dave
Dave Stoll
Las Vegas, Nevada
