Having an issue displaying pipes correctly when put into a plan view for construction documents. The plan view does not "break" pipes that are below other pipes. Appears to work fine for double line pipe (pipe displayed with outer walls on and centerline off, but only if 3D solid is visible), however if we are using single line pipe (pipe centerline only displayed) the pipes all appear to connect to each other (ie no break for pipes running under other pipes). See attached.
Mark Green
Working on Civil 3D in Canada
The way it is supposed to look. Any pipes that are "below" or at a lower elevation are broken to show which pipe is on top.
Edited by
Discussion_Admin
Mark Green
That works for our double line pipe just fine (we use double line or outside walls turned on for pipes 18”+ and only pipe centerline/single line pipe for all less than 18”). We have tried turning on pipe hatch but when just showing centerline it doesn’t break anything.
@Anonymous wrote:
I have tried that as well. As soon as it goes to no plot, it doesn't work.
EDIT: this stupid web site posted my reply WITHOUT the message that I typed -- just the quote and signature. Oh well, try again.
By "Goes to no plot", do you mean you changed the color or assigned the line's layer to No-Plot? He was referring to changing the line's color to something that will cause your STB/CTB file to plot it using an RGB value of 0,0,0. Also dont' forget to make sure the "overriding" line is on top of the others (Right Click on it>Display Order>Bring to Front).
Don Ireland
Engineering Design Technician
If those fail, you can always use a wipeout window to mask the pipe areas. But again, you would need to make sure it was above and below the appropriate pipes.
This only works for the double line pipe because the 3D solid is covering [hiding] the pipe below. Since the single-line centerline pipes do no have this option, there is no break or hide.
Anothe option is to to add text to your pipes so it is obvious what is what, and where it goes: 8"W along the waterline, etc.
Mark Green
