Hi Thomas:
When running thru the Create Sheets wizard, at the Profile Views window, you
can either "Get other settings from an existing profile view" or run thru
the Profile View Wizard. I seem to have better luck choosing the latter
option. When you do that, there should be option for Pipe Network Display.
Not sure if that will help or not.
Sincerely,
Drew Burgasser
CAD Masters, Inc.
www.cadmasters.com
"Thomas Glidewell" wrote in message
news:5776502@discussion.autodesk.com...
Before I jump to in depth with trying to figure this part out can someone
tell if the plan production tools work with pipes. I have gotten to work
pretty sweet with paving profiles just tried it in a sanitary sewer model
and it doesn't draw the pipes in my profile view. Draws the profile view ok
but no pipes.
C3D08 all sp's
