KW-EGA wrote:
> The case was closed, but the issue was not resolved. Autodesk could
> not recreate the error. I can not create sheets from any view frame
> group with or without pipe network data shortcuts.
KW-EGA
If your case is unresolved, please re-open the case and we can continue
working with your data. If you choose to do that, please provide more
information - your drawing had many VFGs and the incident report did not
specify which VFG to generate sheets from, and what settings were to be
used. The few that our QA tried, generated sheets successfully.
Also, it's easier to follow discussions when distinct issues are kept
separate. Please reply to your original thread (or start a new one).
Thanks.
Himanshu Gohel. Civil 3D Team, Autodesk, Inc.
Autodesk Civil 3D Product Information: http://www.autodesk.com/civil3d
Civil Engineering Community Portal: http://civilcommunity.autodesk.com
