I set up the Plan Production tools a few years ago and it works very nicely within it's limitations.
When a long profile view is broken into views for the sheets the default setting is to have the first 4 profile views horizontally across the screen, and then the fifth profile view would be stacked over the first four. The rows would start over with profile views 5-8 above 1-4 and the above 5-8 you get profile views 9-12 etc. Buried somewhere is a setting to allow the profile views to be horizontal across the screen instead of stacked. I set this all up a few years ago and I can't remember where I found the setting. Can anyone help? Did this get removed in C3D 2013? Thanks.
Possibly the Stacked Profile View Options in Profile View Feature Settings?
Stacked Viewss>Yes/No specifies whether to create stacked profile views by default.
When you're using the Create Sheets tool, under the Profile Views section, Other profile view options; select the Choose settings option, then select the Profile View Wizard. From thqt dialog, select the multiple Plot Options section and put a large value in the Maximum in a row: box. See attached images.
