I have a 8'x7' Box culvert with manholes. The manhole needs to sit on top of the 8'x7' boxes. I also want to see the pipe drawn from center of manhole to center of manhole. not stop at manhole wall.
Any Ideas??
Unless you want to spend hours building a part in partbuilder you might try using null structures and manually draft the box and manholes.
Turn off part masking. And similar to what Neil says - I draft a block for plan and profiles
Joe Bouza
