My project is set up with data short cuts. The proposed storm pipes do not show in the cross sections. The pipe network for the proposed storm pipes show in plan view as does the existing pipe network. I have resampled the pipe network, refreshed and regenerated. Nothing I have done corrects the issue. Note that the existing pipes do show in the cross sections
What version are you using? Do you have all updates installed?
Are your styles set up to display the cross section view?
As a test to see if it's a data shortcut issue, try saving the file, promote the network and see if resamplingthe network sends the part to the section views. If this works exit the app without saving and make sure you are fully updated.
John Mayo
Are the pipes perpendicular to the alignment? If your sample line doesn't intersect the pipe wall, it won't display. You might also check the style to make sure that the sectioin display is turned on.
