Civil 3D Forum
Pipes - Using Civil Design 2005
1 REPLY 1
116 Views, 1 Reply
I have created 2 separate pipe runs; new run and proposed run. I want to connect the end of the propsed run to a point in the existing run. How do I connect it and how do I hold the invert at the connect to the existing?
1 REPLY 1
You may want to post in the land Desktop forum but: You will need to have a node on the existing run. Then snap the end of the proposed run to the node. You can adjust the invert in the editors, either graphical or db. Hope this helps, conan witzel
Rail Community
