Civil 3D Forum
Pipes, Profile Views????
4 REPLIES 4
110 Views, 4 Replies
Hello all,
I have a very long pipe network that came into the profile view almost
perfectly. The problem is that two pipes will not draw in profile view. I
checked the inverts and they are correct. The two pipes are referencing the
correct surface and the correct alignment. In the toolspace prospector tab
when I click on pipes, I get a list of all of my pipes. The two that will
not draw in profile view show that they reference the alignment but do not
show a "Start Offset", "Start Station", "End Station", or "End Offset". I
have tried everything I can think of. I tried deleting them and redoing
them. I have closed the software, rebooted, and turned off the machine.
Nothing seems to work. Any suggestions would be great.
Thanks in advance,
Chris
4 REPLIES 4
I don't know if this will help with any suggestions but if I draw the pipe
just snapping to the alignment endpoints without connecting it to the
manholes it will come into profile view. As soon as I connect it to the
manholes it disappears from profile view.
Chris
"Chris Newell" wrote in message
news:5324815@discussion.autodesk.com...
Hello all,
Thanks in advance,
Chris
Does it stay put if you connect it to just one of the manholes? (try both of 'em, one at a time) Might be a bad manhole ... ?
Chris,
Sorry, I can't offer much help, just: Are you on 2007 SP2? The SP apparently corrected a lot of Pipe problems...
Trevor
Hello all,
Thanks for the responses. Turns out it was a bad manhole.
Thanks again,
Chris
wrote in message news:5325379@discussion.autodesk.com...
Chris,
Trevor
Rail Community
