Civil 3D Forum
PIPES: not connecting to structure
5 REPLIES 5
losfotos
2114 Views, 5 Replies
So I have a problem with a structure and some pipes that are attached to it.
In my source drawing for this network I have a manhole that has 2 pipes coming in and one exiting. In the source the structure shows all pipes attached. When I data reference the network, two of the pipes are no longer attached to the structure and everything I have tried so far has not worked.
What I have done so far is:
  1. deleted the network and re-referenced it.
  2. syncronized
  3. moved the structure in the source, syncronized...
  4. detached and reattached the pipes in the source and sync'd.
So far nothing has worked, next I'm going to delete the structure and put in a new one?
Any ideas why this is happening and how to fix it easily?
Carl Simpson
C3D 2015 & 2016
5 REPLIES 5
losfotos
in reply to: losfotos
So I found the fix... the one thing I didn't do. Delete the structure, create a new one and attach the pipes to it.
Carl Simpson
C3D 2015 & 2016
ricardoKWKYM
Worked like a wonder (@2018)
Thank you!
damacylo
Please, I cannot do it, and I have the same problem and I cannot solved it
How you do it?
How do U attached the pipes?
Thank U
Daniel Avila
Hydraulic Eng.
MMcCall402
in reply to: damacylo
Select the pipe and grab the square blue grip at the end. Drag this grip over a structure and you should see a symbol appear (small circle with 4 small lines) This indicates that the pipe will be connected to that structure when you release it.
Another option is to select the pipe and choose Connect to Part from the right click menu. Then select the structure.
Make sure the pipe and structure are in the same network.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
damacylo
in reply to: MMcCall402
I don´t undestand, please help me
Do U have a video that I can undestand better?
I repeat U and tell U again:
Normally U have one pipe for structure to structure
I am trying to connect two pipes for structure to structure
Daniel Avila
Hydraulic Eng.
Rail Community
