Valued Contributor
losfotos
Message 1 of 2 (196 Views)
PIPES: not connecting to structure
196 Views, 1 Replies
02-28-2014 09:17 AM
So I have a problem with a structure and some pipes that are attached to it.
In my source drawing for this network I have a manhole that has 2 pipes coming in and one exiting. In the source the structure shows all pipes attached. When I data reference the network, two of the pipes are no longer attached to the structure and everything I have tried so far has not worked.
What I have done so far is:
  1. deleted the network and re-referenced it.
  2. syncronized
  3. moved the structure in the source, syncronized...
  4. detached and reattached the pipes in the source and sync'd.
So far nothing has worked, next I'm going to delete the structure and put in a new one?
Any ideas why this is happening and how to fix it easily?
Carl Simpson
C3D 2013, SP 2
So I found the fix... the one thing I didn't do. Delete the structure, create a new one and attach the pipes to it.
Valued Contributor
losfotos
Message 2 of 2 (183 Views)
Re: PIPES: not connecting to structure
02-28-2014 10:13 AM in reply to: losfotos
Carl Simpson
C3D 2013, SP 2
