Method? Drawing it manually? C'mon Don.
Mike Norton
Total CAD Systems, Inc. - Houston, Texas
"Don Reichle" wrote in message
news:5107510@discussion.autodesk.com...
So your stating that there's no way to use the method I described as a
work-around, at least?
I'm sure you're searching for "the" method to accomplish your ends through
Civil 3D, but with the lack of response I'm thinking you may be needing to
wait for the next release, or at least an update.
Sorry.
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
C3D/LDT/CD/SVY-2K6
Intel P4-3.00GHz
XPPro 32bit SP2
1GB RAM
Nvidia GeForce2 Ti 64MB
"Mike Norton" wrote in message
news:5106876@discussion.autodesk.com...
The part on how to make the linetype representing the top of pipe in profile
match the linetype used in plan.
Mike Norton
news:5106873@discussion.autodesk.com...
Hey Mike;
Which portion of this practice is eluding you?
That part wasn't evident from your post.
Or do you mean that there's no method currently to turn off the Top of Pipe
in C3D profiling?
That way you could at least use AutoCAD to draw what you need "by hand".
HTH
Don Reichle
C3D/LDT/CD/SVY-2K6
Intel P4-3.00GHz
XPPro 32bit SP2
1GB RAM
news:5103806@discussion.autodesk.com...
It is common cad practice in some areas to use the same linetype for the top
of pipe in profile as is used for the utility in plan view. Anybody figure
this one out yet?
Mike Norton
