Civil 3D Forum
Pipes in pipe network won't label
4 REPLIES 4
deltacoolguy
3050 Views, 4 Replies
Pipes in pipe network won't label.
I have my pipe network in a separate drawing by itself.  It is D-ref'd into the design drawing and into the plan & profile drawing.
Everything labels just fine in the original file and in the design file, including the pipes.
In the plan & profile:
  • the structures label fine, in both plan view and profile view
  • the pipes label fine in the profile views
  • the pipes will NOT label in the plan view.  Right-click, add label... phfft!, nothing.
Any thoughts?
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
AutoCAD Civil 3D 2019
4 REPLIES 4
Jay_B
in reply to: deltacoolguy
A couple possibilities.
From within Model Space of plan viewport, verify the layers assigned within the Pipe Label Style used are on & thawed.
Also check the VP Freeze column in Layer Manager
In the Pipe Label Style in the "Plan" view direction, are the display tab settings correct?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
deltacoolguy
Got it worked out.  For reasons that I do not understand, the default label style for AddNetworkPartPlanLabel had been reset to our "no display" label style.  Which is weird because I created the pipe network drawing and the plan & profile drawing from the same template and they labeled just fine in the pipe network drawing.
Anyway, got the default label style reset and all is good now.  Thanks.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
merci.martin
Had exactly the same issue! Thanks for that 🙂
BrianBenton
I have pipes/structures on the same network, d-ref'd into plan and profile drawing. Some structures label, one does not. Any ideas?
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
Rail Community
