Pipes in pipe network won't label.
I have my pipe network in a separate drawing by itself. It is D-ref'd into the design drawing and into the plan & profile drawing.
Everything labels just fine in the original file and in the design file, including the pipes.
In the plan & profile:
Any thoughts?
Solved by Jay_B. Go to Solution.
A couple possibilities.
From within Model Space of plan viewport, verify the layers assigned within the Pipe Label Style used are on & thawed.
Also check the VP Freeze column in Layer Manager
In the Pipe Label Style in the "Plan" view direction, are the display tab settings correct?
Got it worked out. For reasons that I do not understand, the default label style for AddNetworkPartPlanLabel had been reset to our "no display" label style. Which is weird because I created the pipe network drawing and the plan & profile drawing from the same template and they labeled just fine in the pipe network drawing.
Anyway, got the default label style reset and all is good now. Thanks.
I have pipes/structures on the same network, d-ref'd into plan and profile drawing. Some structures label, one does not. Any ideas?
