My profile is left to right, however the pipe flows right to left. Is this
the source of the problem? If so, is there a fix. Notice the style shows
the arrow should be attached to the bottom of the pipe but is showing up on
top. Also, notice the stationing
is left to right (typical direction).
wrote in message news:5308806@discussion.autodesk.com...
I've been using one of the tutorial files to play around with this label and
I can get the same result you're getting, but only if I change the profile
view style to be right to left. Doing this makes all the labels flip out, up
be comes dow, top is bottom, above becomes below. I tried reversing the
pipe, the alignment, profiles view, and different combinations of all three.
Right to left view seems to be the only way to cause this behavior. ....
and in my opinion, bad behavior.
