Civil 3D Forum
Pipe Type Designation
4 REPLIES 4
319 Views, 4 Replies
I want to create a 96" RCCP pipe designation for labelling purposes.  For what we are doing jsut changing the name of the 96" RCP would work fine.  Is there a way to change the name of pipe in order for the labelling with show up as a RCCP vs RCP.
4 REPLIES 4
jmayo-EE
SAelect the pipe. Right click and choose pipe properties. Go to the part properties tab. Scroll down to the bottom and you should see a field for material. Change RCP to RCCP.
OR
Setup a new pipe label style that displays the pipe desc vs the material and you can edit the desc to read RCCP or anything you want.
John Mayo
in reply to: jmayo-EE
Thank You.  I have a drawing where in the pipe properties the pipe type will not change for some reason which is why i was asking.  Works fine in a ll other drawing.  Glitch in drawing I guess.
jmayo-EE
Try swapping the pipe for another and give it a shot.
John Mayo
BrianHailey
I've been having some serious issues with pipe materials in 2015. Prior to the service pack, you couldn't set the material when adding a part to the parts list and after the service pack (SP1) the option to choose the material is not there at all.
Works fine in 2014 however.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Rail Community
