Has anyone figured out a way to apply the transformed utm coordinates to grid coordinates to a structure table. the point tables have a grid coordinate selection but the pipe structure table does not. has anyone figured a work around for this.
thanks,
Gerry
Civil 3d 2012
Are coordinates required? Will it work to do a baseline alignment for the network and use that as a reference for the structures, then input station and offset in the table?
It might be too late for your current project, but you can setup a point database with the UTM coordinate system, then create a drawing with the grid system desired. When the points are placed in the drawing, they will convert to your grid system. When you layout the pipe network you will be using the grid coordinates, which can when be placed in your table as desired.
