I have setup a reference surface for all of my structures and a sump depth of 0. All of the rims are being inserted about 1.6' above my reference surface. I am not able to grip any of the rims and lower them. It will not allow me to do so. Even if I grip the invert and make the structure extremely deep, I still cannot change the rim. I've had this problem in the past but don't recall how to correct or what I've done wrong in the setup. Any thoughts?
This is due to the structure you are using and the clear distance defined for the pipe. If your pipe size/cover is too close to the frame it pops the rim out of the ground to make it work.
Not knowing part builder well enough I have resorted to using a basis rectangle of cylinder with no frame to avoid this from happening. I assign a block for plan and profile display.
Some day I'll get a grip on PB and get to use it as intended, but for now I cheat.
You can try a different structure type.
Also, you can modify the part in the parts list, and edit its cover conditions to satisfy your conditions.
how's that done?
Make sure that the structure dose not have a surface adjsutment value. Select the the part, right-click menu, sturcture properties. Then under the Part Properties tab, go to insertion rim behavior and set the surface adjsutment value to 0, auto surf adjust to true so it follows your surface model adjustments. Unfortuneatly, you'll have for adjust each structure at a time. hope this helps.
Curtis Hoffart, Drafting Tech
That will not help if the pipe clearance is violated
Joseph,
I haven't spent a lot of time with this myself, but I believe that this can be accomplished in part builder.
Command is 'partbuilder', find your pipe, and edit it's rules and parameters in there. Dont forget to save part family.
Hope this is what you are looking for.
This is turning into a complete nightmare. I can't even swap parts for my storm structures. When I pick a structure it says it is filtered out and won't allow me to use the swap feature. I was always able to swap parts and revise rims in Civil 3D 2011 but not now. Any thoughts on how I can access the swap parts command?
Sounds like you need to do a recover and then a purge of the file.
If that does not work, you may need to recreate the file that your pipe network is in. If you have a stand alone file for your pipe network (which is what autodesk recommends) you will need to take several steps to "recreate" your pipe network (PN) drawing. One method is outlined as follows:
1. create new blank file from same template used for the original PN file.
2. data shortcut your surface and alignment(s) into your new PN file
3. data shortcut your pipe network in.
4. promote your pipe network to your file.
From here you should be good to move forward and replace your previous PN file with the one you just created. This is a method I have had to use before when a file "got corrupted" by the gremlins in the machine.
I had a similar issue recently. Turns out the PartsList was corrupt. I ended up editing the parts list by deleting and re-adding the parts I needed to work with. Took about 30 minutes but I was then able to swap parts with a new one and I could edit again (my sumps and rims refused to adjust, and I could not swap the part out).
I had that happen as well. I noticed that it was because the parts list had been carried over through several versions of civil 3D. I believe it started from 2007 Civil 3D. So I did the same as you and started from the begining and recreated all my parts and rules. It took a while but it fixed all the errors. Before I did it, I tried going through all the routines that are set up to convert the old stuff into the new format, but it was still giving me problems.
Thanks for all of the replies. I was able to workaround by swapping parts (finally was able to do that). I simply used NO FRAME structures and all of my structures defaulted back to my finished grade for the rim elevations.
