I am setting up the pipe network for our storm sewer in C3D 2010 and I have one more bug to figure out.
Why is the structure not showing correctly in profile view? (see Image)
the pipe is connected to the structure and if I rotate the structure, then the pipes show correctly. the structures on the left and right are correct but the one in the middle is not correct.
Ignore the pipe and structures across the top in plan view
The part is correct in the parts list, the style is "display as Boundary"
Solved by nachziger13. Go to Solution.
ANSWER:
In the structure style, under profile tab, change the structure to "display as solid" and not "display as boundary".
Thanks Brian Hailey for the help!
