Yes, I understand that bit Bill, thanks.
I have beavered away yesterday afternoon and this morning and found a few things.
1. I made a new label where I placed ALL the text compnents in one component (if you get my drift). So, now when I drag it, they stay in the same order.
2. I then added 2 "text for each" components (inflow pipes and outflow pipes) and hooked them one by one to the bottom of the text label and then to the Inflow pipes component.
3. So I can drag the label as stacked text now and it doesn't scramble...so I guess the first chap who responded to this thread is correct. Create the compnents in the order that you want them in your label.
This begs the question though. (my original question)
If there is a button to change the order of components, why does the dragged state NOT respect this?
Perhaps this has been fixed in later versions.
Two further points I would like to make regarding labels in dragged state.
Would it not be better if the leaders worked (dynamically) just like the settings in the Qleader command in AutoCAD....where you can set the leader attachment point to the middle of top line when the label is to the right of the anchor point but allow the leader to dynamically re-attach to the middle of the bottom line when the label is (dragged) to the left of the anchor point. I would have thought that this is what all good draughtsmen would want.
Taking a leader line from the middle of a block of text is only good when the text has a box around it (in my view).
Why on earth do folk accept right justification of stacked labels as OK?
When I learned written English, there was not ONE time that I was taught to right justify my text.
This is useful in spreadsheets or for lining up numbers, but I cannot grasp why anyone would want right justified English text on their drawings.
(call me an old fart if you must, but I think it is important)
oh, and I found the leader Justification setting which I have now made false. Thanks for that AutoDESK!
End of today's rant...
Otherwise, happy for the moment...
cheers,
Peter
Edited by: peter.a.thomson@mwhglobal.com on Aug 20, 2009 11:43 AM
