I have changed some pipe sizes in Vistas (pipe network edit), the object sizes are changed in plan & profile views except the pipe sizes in label, it appears the same sizes as before.
I tried to re apply the labels in entire plan & profile, still be the same.
Please have a look.
Thank you
NP
We need something to look at. Probably a label context error, that is, maybe your label is addressing something other than the pipe diameter. We would need something to look at regarding the label, also.
Just wanted to add that I am having this same problem with the pipe labels not updating if I click and drag the pipe to a different size. They will update if I use "swap part". Also, the structures will update either way. It would be better to know why this isn't functioning properly and if I can trust the rest of the labels.
Sorry that this comment is a bit dated but I'm just now coming across this problem & looking for a solution.
If anyone has a solution, I'd appreciate hearing about it.
Thank-you
