I created a new template for a client. This template was created from scratch and now when I try to create a pipe network, I get error messages in the event viewer "unable to run macro:ApplyRule. I even deleted all the parts lists and just used the standard parts list and still got the error. I set the path to the pipe catelog back to the hard drive instead of the network and still got the error. I am out of ideas and I need to deliver this template to the client tomorrow.
Civil 3D 2010 32bit on Windows XP
Solved by tom_berning. Go to Solution.
Hey Tom,
What template is that based on - an Autodesk one that comes out of the box? Also, did you convert the rules to .NET?
Scott Kent P.E.
Senior QA Analyst II
IMPLG
Autodesk, Inc.
100 Commercial Street
Manchester, NH 03101
scott.kent@autodesk.com
Thanks Scott for the reply. I found that the rules had become corrupt in my template. I ran an Audit that removed the rules but I then had to close and reopen the file before I could create a new rule. This template was created from a blank acad.dwt file because of who it was being created for.
