I am trying to change the default setting for "Pipe Flow Direction Method" currently it is set to "start to end" but I would like it to be "by slope". I have to assume there is a way to do this, I have tried everything i can think of.
If anyone could help me out that would be great. Also if anyone is able to provide the definitions of the "Pipe Flow Direction Method" options that would be helpful.
I am currently using Civil 3D 2012, but will soon be moving onto 2014
Thanks in advance,
Why do you need to do this? Cannot you set out the pipe network initially and then apply the rules to the network. After that tweak any parts of the network that require it?
I am looking at alternate ways to create pipe networks, the "by slope" is an option and I want to know more about it as I think it could help with some of our labelling issues and possibly allow more freedom when creating the networks.
If you want to do it EASY and FAST:
Create an alignment along your anticipated pipe path.
Make a profile of this.
Run a Finish Profile along your pipe Flow Line, using slope labels.
Now all you have to do is drag your pipes to fit the slope.
Bill
I have the same issue. The reason for being able to set it, as default, to "By Slope" is it allows for a consistent method to label incoming and outgoing pipes. Storm structures in southern california have an offset built into them (typically 4") from the inlet and outlet. It is important to note this on PLAN VIEW (profile it's quite obvious). The "Start to End" will mess up the label even if the slope of the pipe is correctly showing that it is coming into a structure, it will still label it as out. The only way to fix that is to change the slope direction to "By Slope" and the label works...every time. Besides, it makes ZERO sense to NOT have a gravity pipe system governed by anthing other than "By Slope".
This isn't a wishlist item...it's an obvious bug in the software.
...as a follow up to this. There is a third party program that has a command that will set all selected pipes to "By Slope". Check out SmartDraft, available as a featured app through the Exchange store.
I advise against using By Slope or end to start as you can quickly get very confused with the directions pipes are drawn and levels.
Swapping the flow direction means the pipe Startpoint and endpoint remain the same (this is what the Swappipedirection command does). Anotation can therefore shown two outflow pipes depenent on how it's drawn falls can be read incorrectly. The golden rule of pipework is it goes downhill so draw it so.
I have had this (using the OTB command) before I realised its mistake and opted to write a more useful command to swap the entire pipe direction with start point / end point swapping.
Jeff/Mike,
Thanks for the input! In response to Mike, I have to whole-heartedly agree with Jeff. I have spent hours developing the right label for PLAN VIEW purposes to properly show IN/OUT of pipes at a structure. The only way that I got it to work correctly was to have the pipes set to "By Slope". If they were set to Start/End (or End/start) even when they are drawn correctly, the label didn't show it properly (sometimes 2 OUTgoing pipes, or ALL pipes INcoming...not right!). When set to "By Slope", the label funtioned correctly every time. Granted it may be I did not have the correct sequence of Start/End, or even missed something in the labels development...but that eliminates a step of record keeping that I don't need to keep track of and also possible errors. Thanks though, all input is appreciated.
In response to Jeff, I tend to stay away from the pipes panorama unless I absolutely need to use it. Unless I am able to undock it from the toolspace, it's difficult to use as it is too small on my screen. Besides, the SmartDraft software has so many other tools that I use on a daily basis it is really indispensable...and it gives me a quick keyboard command to change pipes to "By Slope".
Cheers Jeff, I have checked and yes you're correct that does work. Comment retracted:
I use Start/End and label all my pipes in labels without issues. When I see no pipes Out shown I know one is either set End To Start or has been drawn in the wrong direction. I also check the start to end setting in Vb when I test a network and report any which are incorrect.
M
