I want to labe the underdrain offset and elevation in the section views I created. When I try to set up the label under pipe network for section view, I can only show start pipe offset and end pipe offset, not the offset at that particular section. Are there any tips and tricks to labling the offset of a pipe in the section view? the only thing I can come up with is using the section view labels instead and manually added the label in each section. It can be tedious when I have a lot of sections and when the UD get move to a different place.
