Civil 3D Forum
Pipe Networks - Invert display order
6 REPLIES 6
Jay_B
1009 Views, 6 Replies
We are in the process of updating our pipe network structure label styles. The styles are displaying the inverts in a random order (Please see caption)  & we'd like to show the inverts in descending order from highest pipe as first text string & lowest pipe as bottom text string. Is there a way to globally tell civil 3d to always use a descending invert order? Only fix we've found is to disconnect & reconnect the parts in order to adjust invert order. But this is time consuming on large projects & would be nice if there were a more automated option?
Any help is appreciated.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
6 REPLIES 6
Jeff_M
in reply to: Jay_B
You can export out, sort, import back in. (Yuck!)
You could write a program to automate the sorting in C3D.
You could look at a 3rd party application that has done the programming for you. The next release of SincpacC3D has a SortConnectedPipes command that currently sorts by pipe size. I'm sure an option could be added to sort by size or invert.
Jeff_M, also a frequent Swamper
Jeff_M
in reply to: Jeff_M
This feature has been added to he next release.
Grimes_MG
in reply to: Jay_B
Did you ever find a fix/solution to this in C3D 2013 or 2014? I don't necessarily need them in any compass order, but like you, would like them from descending elevation order.
Win7 (x64), EVGA 790i, 8GB RAM, EVGA 8800GT, 250 GB iSSHDD, & RAID 0/1
Jay_B
in reply to: Grimes_MG
Civil 3d unfortunately does not have a sort function (in 2014 either) so we have purchased Sincpac 3d which does have a sort connected pipe inverts by descending order command. Multiple structures can be sorted at once.
C3D 2018.1
C3D 2016 SP4
jmayo-EE
in reply to: Jay_B
I may be mistaken but I think they list in the order of attachemnt, so disconnect all pipes and reconnect in the desired order?? Maybe??
John Mayo
jmayo-EE
in reply to: jmayo-EE
...and yes this would not be a lot of fun if you have hundres of stc's...
John Mayo
Rail Community
