lambertb
Message 1 of 15 (2,134 Views)
pipe networks in section views
2134 Views, 14 Replies
04-12-2011 05:23 AM
I would like to show a pipe network structure on my section view. The catch- the structure is 10' away from my sample line. Is there any way to project structures onto section views? Thanks. C3D 2011
C3D 2014 SP2, Windows 7 Enterprise 64-bit
Dell T3500 workstation, too much ram to post
Go for the processor!
Distinguished Contributor
ksorsby
Message 2 of 15 (2,014 Views)
Re: pipe networks in section views
09-14-2011 05:03 AM in reply to: lambertb
Bump to this one.
Is there a way to project a pipe or structure onto section views (as opposed to pipes crossing the sample line)? If it can be done for profile views, surely it must be possible with section views?
Cheers,
Kevin
lambertb
Message 3 of 15 (1,955 Views)
12-29-2011 08:34 AM in reply to: lambertb
Is this possible in Civil 3D 2012?
ksorsby
Message 4 of 15 (1,928 Views)
01-03-2012 02:51 AM in reply to: lambertb
Not as far as I am aware. It's a surprising and important omission in my view.
lgmunoz
Message 5 of 15 (1,925 Views)
01-03-2012 04:45 AM in reply to: lambertb
define a a sample line section where your pipe and sctructure is located
ksorsby
Message 6 of 15 (1,921 Views)
01-03-2012 05:15 AM in reply to: lgmunoz
Yes, that looks good. What about where you have pipes running along the length of the road, ie. parallel to the alignment as opposed to perpendicular as you've shown?
Kevin
lgmunoz
Message 7 of 15 (1,917 Views)
01-03-2012 06:18 AM in reply to: lambertb
select your pipes and structure, right botton click and select draw in profile view go to your profile and click in any part of it
lambertb
Message 8 of 15 (1,914 Views)
01-03-2012 06:21 AM in reply to: lgmunoz
My problem exists due to having to make so many sample lines (one for each structure, plus the 25' normal sample lines). If a structure is a small distance away from a 25' station I would like to project it to that station. It seems like the structure station and sample line have to be the same.
ksorsby
Message 9 of 15 (1,904 Views)
01-03-2012 06:33 AM in reply to: lgmunoz
I think we might all be talking about slightly different things - you can right click pipes and structures and project onto a PROFILE view  as you've shown but not a SECTION view. Capitals for emphasis, not shouting! ;o)
For Section Views you can add a pipe network to the list of sources under Sample Line Group Properties and any crossing pipes/structures will magically appear on all section views under that group.
I was wondering if it was possible to just project 1 pipe or structure onto a single section view - which it appears it isn't.
Cheers,
Kevin
lambertb
Message 10 of 15 (1,547 Views)
11-13-2012 12:35 PM in reply to: ksorsby
Does Civil 3D 2013 allow you to project pipe network structures onto section views? For example 25' sample line spacing, a manhole at +20, can you project it to the +25 station?
Thanks.
