Hi there ...
I'm working on a projet and i need to calculate the rock from the geologist survey VS the normal earth on it.
Until now things are simple.
But where it gets twisted it that i need to calculate the cut from the projected network pipes.
I did a quick sketch so we could all understand what i'm trying to say :
Id like to generate a surface that will generate the cut surface for the projected network (Sanitary, rain, water) with a given Y offset (for the material to be put before puting the pipes).
Is it possible to give multiple points of controls to an assembly ?
