Civil 3D Forum
Pipe Network
2 REPLIES 2
martin888888
187 Views, 2 Replies
Pipe Network
I have a pipe network created for underdrain pipes.  I want to model all 40 pipes and have them in the same network that I created.  Is there a way to do this?  When I create the pipes it puts them in there own network and I dont want 40 pipe networks.
2 REPLIES 2
Jeff_M
in reply to: martin888888
You could just draw the pipes in the correct network. Or, if converting 3dpolys into pipes, use the MergePipeNetworks command.
lsimms1
When you create the pipes, you need to edit the existing pipe network.  It sounds like you are doing new by layout or something similar.
Rail Community
