I have created a new pipe network in a drawing that contained previously created networks. When the Network Layout Toolbar came up the dropdown for pipes was empty. If select a start point a network structure is placed there but at that point it stops, it won't allow entry of a second point. Last week IT rebuilt my Windows profile. Would that cause the problem, and any ideas on how to fix the issue? Thank you,
Solved by Jay_B. Go to Solution.
Is your Parts catalog local or on network?
You can verify the path it's looking to here. (see caption).
