I am trying to convert a pipe network to a SHP file for use in GIS and am successful using the Pipe Network to SDF to SHP workflow but I would like to have all of the fields of the pipes come through to the SHP file. Converting the network to a SDF only results in the following fields in the SDF: pipe name, network name, pipe ID, pipe OD, length, slope, start and end inverts, structure start and end, and the part size name.
Is there a way to export the pipe network using some othwer workflow in which the pipe fields exported are not limited by the SDF?
