I am trying to set up our compnay Storm Structure Data Table with our Pipe Network Information.
I made Structure Styles for each type of Inlet/Manhole/Catch Basin/etc and with each type of casting we use with them. Also inside this style in the description I put what I want called out in our table each time for these structures.
BUT, when I got to make my structure table it won't let me access structure style info into the table. Am I missing something or do I have to manually put this in every structure when I put them in?
Any help would be appreciated.
I am in AutoCAD Civil 3D 2014.
The table definition calls upon the structure properties not a given style. What are you aksking of the table that is not in the table style composer?
Joe Bouza
is there a way to give a certain structure properties these defined descriptions? I can't find a place that allows you to customize that then.
