I have a pipe network and I made a structure table for that pipe network. One of the columns I am attempting to display the invert out of the structure. Right now the Text Component Editor has
<[Connected Pipe Invert Elevation(Uft|P2|RN|AP|GC|UN|Sn|OF)]>
The problem is if the structure has multiple connected pipes it pulls 1 of the pipe inverts and displays, which is usually any upstream invert. If the structure only has 1 pipe connected it will give me that invert, which is the generally the downstream invert of an inlet. I want to be able to display the Down Stream Invert, has anyone been able to accomplish this?
Thank you for the help.
Solved by BrianHailey. Go to Solution.
When you add the column to the table, remove the default component and add in a "Structure out flow pipes" component.
Ok I did that and I get this as my table
Why am I getting multiple inverts showing up? Does that mean some of the directions of my pipes are drawn in incorrectly?
Don't know. Can you share the table style and the pipe network? Remember, just because a pipe is the lowest elevation doesn't mean it's the outflow pipe. Pipes have both direction and flow direction.
That is probably the issue at this point. I can share the style and network but how do I get it into a format you could see or I could send in an attachment?
I did have some pipes that had the wrong flow direction. Thank you for the help I was able to get it working now.
Awesome! Good to hear!
