I've been using pipe network in Civil 3D for some time now and all I can say is I can't wait for them to rewrite it!
I've had acouple of problems with some of the default parts for the UKIE template which I have managed to fix manually but there is stil one problem I can't seem to solve. For some reason my type E manholes show up in plan and section but don't show at all in object viewer. I've even tried to create a new drawing and place a new network but again the same thing happens.
I've tried going into part builder, validating it and saving it, reload the catalog etc. just incase.
Anyone else have this problem? Any ideas?
the style that you have assigned to this structure type, can you check and verify under its DISPLAY tab if it is set to display the structure in MODEL and SECTION views?
Thanks for the reply.
It says that the appearance of this object is not controlled by he display system.
It's using the STANDARD style just like the rest of the drainage, I'm starting to think that it's a glitch in Civil 3D but I'm not sure mhow to get around it.
