Civil 3D Forum
Pipe Network Structure Label Pipe Install Note
4 REPLIES 4
clayton_lewis
612 Views, 4 Replies
Using Civil 3D 2010, I have my Storm Water structure label as follows:
Northing, Easting
Reference Alignment, Stationing
Construct Storm Sewer Structure
Storm Sewer Structure Size
Top Elevation
Install Length of Invert In Pipe
Does anyone know how to show the length of pipe, material, and direction of the invert in pipe in a structure note?
If it involves putting together an expression, does anyone of any ideas? I'm kind of lost.
Thank you in advance for your help.
-Clayton
4 REPLIES 4
SethHall
in reply to: clayton_lewis
Hi Clayton-
I think the "text for each" component will get most of these for you. Add that component and then drill down into the text contents to see what options are available to add to your label.
856iCFE1B8540AB59632
Hope this helps!
Seth Hall
Product Owner
Model Builder
clayton_lewis
in reply to: SethHall
Here is what is available when adding "text for each" and the pipes connecting to a structure.
858i1B1B54D567BB1007
There is nothing available for the length of pipe connected to the structure.
klugb
This one is a BIG pain for us. You cannot get the pipe length from the structure labels.
So, instead of having it part of the structure note (like we have for years) we are now creating pipe tables with this information.
Bruce
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
SethHall
You do get the direction and material, however you are correct; length is not present. Unfortunately I do not know of any method to get the length to populate a structure label.
I would suggest you request this functionality by visiting Product Feedback
Seth Hall
Product Owner
Model Builder
Rail Community
