I have a pipe network created that is shown in multiple drawings. I created labels for the structures showing Rims and Inverts. Does anyone know how to put the Rim info on a different layer than the Invert info? Right now the label has 3 different components...I feel like there has to be a way to put each component on different laters...anyone have thoughts?
thanks!
Don't think so, sorry. Each component can be different colours, but not layers. You may need to make different labels to achieve what you need. Wish they would allow componant layers though.
Mark Green
Working on Civil 3D in Canada
Ok, thanks. That's what I was afraid of. I have a plan that shows the grading of the site and another plan that shows the pipes and structures. I want to show the Rim elevations on both plans, but the Invert elevations only on the utility/piping plan.
Do you know if I use data shortcuts to bring the pipe network into my Grading plan, can I add structure labels to that plan? Right now I have a base file with the structures and labels that is XREFed into both plans.
What version are you working in? I think since 2010 or 2011 you don't need to data shortcut them in if you are just adding labels. You can just add the label to the structure in the x-ref.
So freeze off the labels that are in the x-ref and add new labels in the Grading Plan showing just the rim elevation.
Mark Green
I'm in Civil 3D 2012. You're right, I don't need to data shortcut the structures in. That's good to know...thanks!
