Civil 3D Forum
Pipe network structure grid stretching up way direction only
10 REPLIES 10
Message 1 of 11
najeebcad
842 Views, 10 Replies
I have created one new structure in pipe network catalog. When I create the pipe network profile with my new structure, I am unable to modify. If I click on the grid Top / Bottom of structure it will stretch to up way direction only, I cannot stretch to down way direction.
After few stretching on top side grid, the whole structure will move to up way direction; I cannot move structure to down. Kindly give a help!!
Files attached
Thank you
Najeeb
10 REPLIES 10
Message 2 of 11
cyndycyndycyndy
in reply to: najeebcad
Is this a custom structure?
Cyndy Davenport
Civil BIM Professional & Enthusiast
Contributing Author to Mastering Civil 3D
Decades of Experience
Message 3 of 11
najeebcad
in reply to: cyndycyndycyndy
Yes, Do I need to adjust any values or calculations in part builder ?
Message 4 of 11
cyndycyndycyndy
Check your range values for SRS.  Perhaps you have met your max.
Cyndy Davenport
Message 5 of 11
najeebcad
Did not reach the maximm of SRS value, still remaining few meters
Message 6 of 11
cyndycyndycyndy
If you want, you can zip your structure dwg and xml file up and I can take a look at it.
Cyndy Davenport
Message 7 of 11
najeebcad
Thank you very much for your help.
Please find the attached the required drawing, XML & Structure size schedule files. I have made two model of the same structure (Structure Type D01 & D02),. Kindly have a look.
Kindest regards
najeeb
Message 8 of 11
cyndycyndycyndy
Ouch.  You have a grip at the bottom of your structure.  The top tier and bottom tier are not constrained properly from first looks.  I've only looked at the first structure mind you.  I will take a closer look after my drive home (east coaster) and try to help you sort this out.
Cyndy Davenport
Message 9 of 11
najeebcad
Thank you, your help much be appreciated.
I'm not familiar in Civil 3D part builder, save as the drawing from existing pipe metric catalog and tried to modify.
Need to create catalog as per the municipality standars.
Type D 01 save as from Eccentric Cylindrical 2-Tier Circular Frame SI
Type D 02 save as from Rectangular Structure 2-Tier Circular Frame SI
Regards
najeeb
Message 10 of 11
cyndycyndycyndy
When you test the original eccentric cylindrical 2-tiered structure with circular frame and put it in profile, you can see that there is something off with it.  It appears the frame has a 5 meter height and the pipe invert isn't being directed to the junction section.  And the cylindrical transition is nonexistant.  Therefore, there seems to be something that isn't right with the original structure.  When it was copied and altered, more problems resulted.  The structure needs to be rebuilt to produce the results you need.
Cyndy Davenport
Message 11 of 11
najeebcad
Thanks for your advise. Will do the same way which you said.
I have posted two topic, could you please have a look on that
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/DEFAULT-Sump-Depth/td-p/3104538
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/APPLY-RULES-to-an-entire-pipe-network/td-p/3103610
najeeb
Rail Community
