Civil 3D Forum
Pipe Network - Profile Sump Display Incorrect
21 REPLIES 21
Message 1 of 22
sduffin
5339 Views, 21 Replies
I am having problems with the display of my structures in a profile view.  Previously, when I change the inverts of the pipes connected to my structure it would automatically adjust the bottom (sump) of the box invert to match my lowest pipe.  However, for some reason it has stopped doing it and is now displaying the sump invert incorrectly.  I have my style set to "Display as a Boundary".  I have edited the structure sump to be by both elevation and depth, but it does not update the sump elevation.  I have tried to grip edit the sump but it seems to be locked at a certain elevation.  I have a profile with 10+ structures and they are all at multiple depths.  I realize there are minimum depths allowed by the structure, but I have exceeded the minimum depths in all cases.  Attached is an image that depicts my problem.  No matter what I do to change the depth it stays locked at a certain elevation.
Any suggestions would be greatly appreciated!
Scott
Civil 3D 2011, SP1
2269iE2E3EA2B4865E828
21 REPLIES 21
Message 21 of 22
capt.crayola
in reply to: jschlichter
Thank you - Thank you!!
I had the same problem, and swapping the part out worked!!
Sean
Sean
Dell Precision M6700 laptop
Intel Core i7-3740QM quad core 2.7Ghz with 16 GB Ram
NVidia K400M 2GB video, Windows 10 Professional 64 Bit
Message 22 of 22
santhosh1
Check with Pipe Network Catalog settings, Then disconnect and Connect from Pipe to Structure and save and SYNCHRONIZE, Reopen the drawing it works.
Rail Community
